Didn't find any reference for the standard wing build so I thought I'd share my build process.
1. Cut out both wings, making sure to flip the plans. Although the plans do not show it, you will need to remove the paper and melt some foam on the top of the wing so the wing will meet the tapered spars.
2. Join the bottom of the wings as per FT norms - tape on one side, bead of glue, wipe off excess. I then installed the spars and servos. I was concerned about the center where the spars meet so I added some popsicle stick reinforcement. Was undecided about landing gear so I went ahead and added pieces of paint stick. In retrospect probably should have continued it between the spars as well.
3. Fold over and glue like a normal FT wing - LE, spars, servo top, etc...
4. Made my own dihedral gauge with a 5 cm height.
5. Finished product!
