Accessing the damage...
the wing was held with rubberbands which came off on impact. just a wrinkle in the skin in the center...
wingtips already had wrinkles from pulling high G's
Fuse accordioned but I think I can flatten and smooth it out with a monokote iron and some hot glue.
You cant see it in the pics, but the battery blew thru the fuse into the power pod and hit the rear motor shaft breaking it.
The bolt on prop adapter is bent, and the nosecone mount split and prop broke.
power pod is trashed too...
I really loved flying this plane once I got her dialed in. It was a little sketchy at first but I kept at it adjusting cg and finding the right motor and battery. Got her fairly flyable, then I met with nNic at FF2015 and he told me of a redesign and new cg point and to reduce my control throws and WOW! what a different animal she became! Flew like it was on rails! Very predictable flite lines and became confidence inspiring. I wasn't afraid to get in close to the trees in the video that I'm flying over. I even touched the leaves with a wingtip a few times... on purpose!!!
this is a great plane design and if your an experienced pilot and on the fence about making the commitment of time to build this plane, just do it! You won't be disappointed...
