Inspiration:
90mm EDF, 80A ESC and 3000 6S battery with no plane.
Looked around, the diamond looks appealing. but I thought about what else... and decided to design the Romanian Air Force IAR-9 SOIM (hawk)
Plane Specs:
from the Wiki Page:
General characteristics
Build Specs:
TBD
Plans:
Alpha Set 90mm EDF IAR-99
1 of 4, 2 of 4, 3 of 4, 4 of 4
Come build with me...
Plane Specs:
from the Wiki Page:
- Crew: 2
- Length: 11.01 m (36 ft 1 in)
- Wingspan: 9.85 m (32 ft 4 in)
- Height: 3.9 m (12 ft 10 in)
- Wing area: 18.71 m2 (201.4 sq ft)
- Aspect ratio: 5.2
- Airfoil: NACA 641A-214 (modified)
- Empty weight: 3,200 kg (7,055 lb) equipped
- Max takeoff weight: 4,400 kg (9,700 lb) Trainer; 5,560 kg (12,260 lb) Ground attack
- Fuel capacity: Internal:1,370 l (360 US gal; 300 imp gal); External:up to 450 l (120 US gal; 99 imp gal) (in 225 l (59 US gal; 49 imp gal) drop tanks)
- Powerplant: 1 × Turbomecanica/Rolls-Royce Viper Mk632-41M turbojet, 17.79 kN (4,000 lbf) thrust
- Maximum speed: 865 km/h (537 mph; 467 kn) trainer, clean
- Maximum speed: Mach 0.76
- Range: 1,100 km (684 mi; 594 nmi) Trainer with internal fuel; Ground attack with internal fuel 967 km (601 mi; 522 nmi)
- Combat range: 345 km (214 mi; 186 nmi) hi-lo-hi at 5,280 kg (11,640 lb)all-up weight
- Service ceiling: 12,900 m (42,300 ft)
- g limits: +7 / -3.6
- Rate of climb: 35 m/s (6,900 ft/min) at Sea level
- Wing loading: 235.2 kg/m2 (48.2 lb/sq ft) Trainer; 297.2 kg/m2 (60.9 lb/sq ft) Ground attack
- Thrust/weight: 247.5 kg/kN (2.42 lb/lbfst) Trainer;312.7 kg/kN (3.06 lb/lbfst) Ground attack
- Guns: 1 × 23 mm Gryazev-Shipunov GSh-23L autocannon
- Hardpoints: 4 underwing hardpoints capable of holding 250 kg each and 1 central hardpoint capable of holding 400 kg with a capacity of up to 450 kg (990 lb) of stores (the underwing hardpoints are wet capable of carrying 225l drop tanks),
- Rockets:
- Missiles:
- R-60 air-to-air missile
- Python AAM
- R.550 Magic AAM
- Bombs:
- BEM 250
- BE 100
- BE 50
- Mk 82 general-purpose bomb
- Opher infrared-guided bomb
- Laser-guided bombs
Build Specs:
TBD
Plans:
