A dialed in, handed to ya Nutball is an ok trainer. It has the tendency to not be dialed in for beginners when built by beginners, and instead is ready for the most capable hands. If the CG is correct and the throws minimized, a Nutball will fly sedately. If the CG is too far back or the throws are too large or both it will turn around in the space of it's own diameter, in any direction or all three at once, which is amazing but a little skeery if you just wanted to go straight out 20 feet.
Man I wish I had seen a post like this one a year ago
Growing up a built a bunch of balsa and tissue planes - but due to being a kid and on kids budget they never got more than rubber power and free flight. Always wanted to go RC and powered but it never happened. Thought about it a few times once I got older and had bigger budgets...but the expense still scared me. Stuck to cars and boats - they were expensive enough to repair after crashes and they stuck to 2 dimensional movement so I figured I'd have fewer crashes to deal with (yeah...right!)
A few years ago I saw how the prices on RC gear were dropping and picked up a used 4 channel TX/RX/servo set and planned on building a kite photography rig...until I realized how expensive a kite to lift the cameras I wanted to lift would cost. So the gear collected dust.
Until a few years later when Make magazine ran an article on the Medicine Man glider. I ordered one the day I saw it. Built it, put the radio gear I had in it (had to buy a new RX because the one I had wouldn't fit) but never got past a few small hand launches because I knew I didn't have the skills to actually fly it and being a balsa model would be a lot of work to repair from a crash. (Heck I manged to rip the tail off and take a chunk out of a wing just doing hand launches in a nice grassy field!) So it went back on the shelf until I could build up something to train with first.
A year ago the itch to fly came back and I picked up a little 4 channel FP heli to play with. Loved it even though I went though a ton of parts on it. Ended up picking up a t9x transmitter since it would bind to the heli out of the box..and I figured it would be a good excuse to finally try some planes.
Was saving up (my adult budget was suddenly gone due to the addition of a child to our family) for an Easy star but didn't really like the idea of buying an RTF or ARF plane...I've just always enjoyed building! So I started researching things I could build.
Then all in the same month I heard about the Nutball, the FT swappable plans came out, and Make ran another article with an easy to build foamboard plane, and I stumbled across the experimental air armin wing. We've got a couple dollar trees in town so I grabbed a few sheets of board to play with. Built an armin wing and fuse for a noob tube but knew it would be too much to fly...but kept hearing good things about the nutball.
So one afternoon while my girls were out I built one with the foamboard I had on hand. Ordered the suggested hardware and suddenly I had a plane ready to fly! I started with 2 5 packs of props and headed out to the biggest grassy field around me (living in the desert those are kind of hard to find!) on a nice calm day and thought I'd teach myself to fly. I was bored with sims already and figured I could handle it.
Well, that was a bit less than a year ago and I lasted all of about half an hour at the field before I was out of props. The nutball was just too much for me to handle!
I figured I should go back to my original plan of saving up for an easy star - but now decided a Bixler would be better. Then summer hit. Which here in the desert means huge AC bills and tiny hobby budget. My gear collected dust again.
Then about a month ago I ordered up the bits I needed to fix my heli again and while I was waiting for them to arrive from overseas checked out the new LHS that had opened over the summer.
Came home with a couple of props. They didn't have the nice cheap bags of 5-10 props I was used to seeing online. Just nicer heavier duty props that cost as much each as a bag of 10 from China. But I was itching to try the nutball and had figured out that I needed to setup some dual rates and expo. I also made up a set of landing gear out of a coat hanger and some foamboard to add a bit more weight up front. Got it out last week and with the rates and expo I was suddenly able to almost fly it!
Unfortunately with only 2 props to fly with and neither being "right" (The closest thing I could find at the LHS was a 9x6 and an 8x6) it was still a little hard for me to control. I suspected the other problem was my control rods. Without a LHS I had searched locally for a suitable material. Couldn't find piano wire anywhere locally. I ended up using some machinists wire which was the stiffest thing I could find that would still fit through the holes in the control arms. But it was still pretty weak and I suspected it was the final thing keeping me from having any success. I only destroyed one of the 2 props this time but smashed another firewall ended my day. At least this time I managed to keep it in the air more than a few seconds though so I knew I was getting closer. Ordered a bag of 10 cheap props from a US dealer so they'd get here before this weekend and hoped they'd arrive in time to try again!
Sure enough the props came this morning. So today I ran back to the LHS and picked up some nice piano wire now that I had a local source! While my lipos charged I made up new control rods and a new firewall (and rebent the motor mount which remarkably hasn't actually broken yet.) Only problem...the wind. We actually had wind advisories today. Crud.
But never being one to listen to my sense of better judgement after my girl woke up from her nap we loaded some kites and the nutball in the truck and headed up to the park. It was her first time flying a kite and she loved it. So while she and mom were busy with the kite I decided what the heck, let's try the nutball again even if it is probably too windy.
Well, not only was it too windy but it was also too late and the wind was basically coming right out of the quickly dropping sun. But with proper control rods, a correct 8x4 prop, and my throws dialed WAY back with a good bit of expo....Holy cow I was able to fly!
Not very well. I was just on a 2 cell and the wind was strong enough that I could get off the ground...but couldn't really go anywhere - just kind of hung there and fought the wind. Well, I did bring one 3 cell with me....Popped it in...and suddenly I could fly!
Still ended up going through 3 cheap props. One from and emergency landing in the parking lot when the wind got a hold of me. And two from nose in crashes when I lost the plane in the sun.
My nutball looks like heck. I'll have to get some photos tomorrow...but it's pretty beat up. Still I was actually able to fly for a few minutes this time! Can't wait to get it out tomorrow morning when the wind should be calm and the sun will be on the other side of the wind!
I'd still like to get myself a Bixler...but it's just not in the budget. Instead I finally pulled the trigger on the motor I need to build an Axon and will put more of this foamboard I've got on hand to use over the next few weeks while I wait for it to get here.
Big thanks to FT for the swappable plans - but also to the creator of the nutball and all the people over the years who've contributed to making this hobby more affordable! Since this totally from scratch nutball has seen better days and is getting pretty crumpled I'm thinking I'll have to order up the 3 pack in the next week or two - seems like a good way to thank FT and get me some more planes
TLDR version: Limit the throws, keep the weight forward, and make sure the control rods are stiff enough and it's a much better trainer! I'm still not convinced it's actually a good trainer...but it's what I've got for now and with those 3 things taken care of I'm starting to have some luck actually flying it instead of just crashing it! Glad the plane itself only cost about $2 in materials to build! But if I had it to do again I'd look into something with a more protected prop/motor to start with. I don't mind seeing my $2 plane smash into the ground...except that the most expensive part (the $10 motor) is usually the part that seems to hit hardest!
Now I need to get as much built and flying as I can before summer hits and my hobby budget gets diverted back into the "keep the house under 80" budget
