Hey all! Bought my first multirotor yesterday, a Blade Nano QX. I'm having a lot of fun crashing it around my living room.
After about a day (and probably upwards of 100 crashes, although at 18 grams the crashes are pretty uneventful), one of my motors is making a loud buzzing/humming noise. It goes off balance to the left (I'm correctly calibrating it on a flat surface). I can correct it by calibrating the controller way to the right, but then any change in yaw causes it to corkscrew to the ground.
I noticed if I flick or blow on the other 3 props, they spin up easily and gradually slow down, but this 4th one I have to blow very hard or flick it to get it to turn, and it stops very abruptly compared to the others. I took the prop off and cleaned the carpet fuzz off, changed the prop, and checked to see if the cam looked bent, but it doesn't seem to have helped.
Is there a next step to fixing it or do I need to buy a new motor, and if so, are motors typically proprietary to the company or is there a generic way of describing a particular motor so I can find replacement parts?
Thanks!
Hashtag
Thanks!
Hashtag
