OV-10 Bronco Motor choices
tomlogan1
I am planning on scratch building an OV-10 per Sponz' plans. I have the following motors available to me:
2812-1534 kv uses 7x6 props
HK 2826-1000 kv using 9 inch props
I either case planning on 2 x 30 Amp ESCs and 2200 mAh battery
Which would be the better choice for the Bronco?
Thanks
mrjdstewart
i have this on my build list as well. i think the 9" props may be a bit big for the build, not for your motors, but for the build. may look a little big for "scale."
i plan on using 2x Multistar 2213-980kv motors w/ a 20A esc and 7x4x3 blade props with a 3S-2200. i have used this motor/esc on a FT Cub with a 8" prop and it does really well, so i think 2 of them on the Bronco will be perfect.
good luck with the build. i have mine printed but haven't tiled them yet.
laters,
me :cool:
tomlogan1
Never got around to decorating but this plane is very stable and would probably be a great fpv platform. I used the 2812-1534 motors with 7x6 counter rotating props with 2 30 amp escs. A little awkward to hand launch but very stable once in the air.
