matjey
It's been a while since my last post to this forum. A couple of thing have hold be back down from being actively involve with RC. But now the sun start shining again and I'm up for a great start.
This time around, I've done designing and building up the P-38 model with a pusher setup motor. Pusher setup has been one of my preferred setup as I tend to broke my prop on regular basis due to bad landing![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Pretty much everything is on my published article here: https://www.flitetest.com/articles/p-38-pusher-mj-another-variant-of-twin-boom
The build will have below spec:
Motor: 1450kv
Prop: 8x6
Batt: 1800mah Lipo
30A ESC
3 x micro 9g servo
I would not touch on the build process in details but rather to write on the outcome of the flight report after have successfully maiden it. The build process take less than a day in fact it just took me 4 hours from cutting the depron and assembling it all together.
The first maiden with had launch can be a bit scary if this was your first time. Watch out for that prop, don't get yourself cut. To me, it is a breeze for the maiden. The plane flew right of my hand and gently climb up against the head wind. Not that mild banking left or right as normal warbird like P-51.
Not much of the aerobatic that I can perform on this baby. It is the aileron throw is not that big enough and regarding the design of it, I planned it to fly slow and calm. Well, if you want to be able to perform trick with this plane, one might need to increase the aileron throw and shorten the wing depth.
If you happen to build this one for yourself, please tag me along. Would love to see how it goes. Feel free to comments, suggest or critics. Hopefully I can improve my design skills in the near future as currently I'm working on another project. A Grumman A-6 Intruder using pusher motor setup.
Cheers![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Motor: 1450kv
Prop: 8x6
Batt: 1800mah Lipo
30A ESC
3 x micro 9g servo
Cheers
