So I'd picked up 4 Park 300's with the intent of making a quad, but forgot the KK2 board, and its been on back-order for more than a month.
So I'm making a FT Flyer-Twin with differential thrust... because... I can!
I started soldering connections and testing ESC and motors, and after calibrating ESC, the motors do not start moving at the same time. One will start spinning at 10%, another will just kinda twitch and not start spinning until 15%. Once they're spinning, they'll keep spinning if I slow them down around 5% or less. I switched ESC between motors, and behavior is the same, so it seems to be a motor thing...
Is that normal? Do I need to do something to calibrate the motor or something? Does it just take some time to break in? Tips? Tricks?
Thanks!
Thanks!
