After watching the FT "Face Off" video, I became intrigued by the idea of using Polymorph to make a mounting clip for my GoPro on my new FPV Wing.
A bit of a search on Google told me down here in Australia it is called "Instamorph" and was available for a very reasonable $11 per 100g at my local JayCar electronics store. So off I went to get some...
I had my first go tonight and I have to say it really is awesome stuff! It's pretty easy to work with, molds very well and cuts easily. Here are some pics of my first GoPro clip attempt...
If anyone else is thinking of giving it a go, I did learn a few lessons along the way...
Anyway, going to mount this in the wing over the next couple of days to see how it goes...
Cheers,
Mike
- Don't use a plastic container to melt the pellets, this stuff REALLY sticks - use a mug or glass jar instead.
- If you are going to roll it out into a sheet, keep moving it around so it doesn't stick to the work surface (or use something like a glass board).
- Cutting it when rolled thin is very easy if you use a sharp knife and cut whilst it is still a bit soft and translucent.
- If you want to stick two bits together (like a second lamination for reinforcement) you need to re-soften BOTH pieces or the bond won't be so good.
Cheers,
Mike
