Hi All
I've got a problem, I'm not getting the TX to bind to the RX, I'm doing all according to instruction.
Holding the bind button on the module, while switching the TX on, while both dip switches are down, the getting beeping.
Then I have to hold the F/S button on the TX while connecting to power, witch I did, then Both LED's on RX go solid and stay there... not binding... Have tried with and with out the jumper on the RX. And at various distances from each other.
The TX says FM-PPM, and in settings I have also set it to PPM as in the instructions.
I'm I doing something wrong? Or are the RX not compatible with the TX?
Derik
RX with LED's on
The TX in question (Excuse the dirtiness)
The Module, with both dip switches down & bind button to the bottom right of dip switches.
Derik
RX with LED's on
