@Javiester - awsome build! It looks like you've mastered the MS build techniques. Did you use any filler on the seems?
@rockyboy - can't wait to see yours finished and flying!!
That spinner looks perfect!The props finally came in, along with a proper fitting collet, so I was able to put that in place finally.
And in order to get the right spinner stand off from the body, I had to move the motor mount a good bit (wasn't glued in yet) and completely redo the battery box approach. Now it's back in a position much closer to the plans, but will still be held in with foam and balsa blocking instead of velcro.
So let's check out that spinner! Nicely centered, even with the down and right thrust line.
A little gap between spinner and fuselage from the side angle, but necessary so the prop doesn't hit the nose on the bottom right edge.
So it's time to get ready for the final paint! First I used 400 grit sandpaper to go over all the doculam to rough up the surface, and then cleaned that with rubbing alcohol. Then it all gets a light spray coat of a plastic adhesion promoter - basically a clear and flexible primer for plastics. There are a couple of these products available, the one I'm using was designed for auto body repairs.
REALLY looks GREAT Rockyjon!!! 💯👌😜 The Spinner turned out to be perfect. Moving the Motor didn't upset the balance, did it??The props finally came in, along with a proper fitting collet, so I was able to put that in place finally.
Good idea! That might be just the trick to get paint to stick tight to doculam. You'll know for sure if you plan to use masking tape.Then it all gets a light spray coat of a plastic adhesion promoter - basically a clear and flexible primer for plastics. There are a couple of these products available, the one I'm using was designed for auto body repairs.
