paradawks
I just built my first plane - an Explorer - and bought power pack B to go with it. I believe that the included 9x4.5 prop should be installed with numbers facing forward (which is backwards onto the motor shaft). Unfortunately, in that direction the props don't slide all the way down the shaft - bind where the threads end. This makes it so the included nylon nut doesn't have enough threads to fully engage. Do these props need to be reamed out a bit to fit in the pusher direction, or is it okay to mount it further out with fewer threads? Maybe I'm missing a better solution?
Numbers facing backwards from direction of travel it fits...
Numbers facing forward, it does not...
