Just curious, but how do folks do glide tests...like with electronics and battery plugged or unplugged? No electronics/power pod at all?
By the time I finish typing this it is likely that you have been swamped with posts but I will continue just in case they are still asleep.
Glide tests are best done in the way you wish to fly it, and this includes weight. So normally you complete the build, and the fitout, fit the battery, adjust the control throws and check the control surfaces operate properly and then launch it.
Basically as you would perform the maiden but without motor power.
Just one thing though it is EXTREMELY IMPORTANT to ensure that your launch has sufficient power and speed to ensure that the plane being tested actually achieves aerodynamic flight. In my case as I am starting to feel old I use a bungee launcher and since doing so I have had a lot more uneventful glide tests and maidens than even before.
Have fun!
