Hello,
I've been having some weird issues with my quad... when I hook up my Naze32 to Cleanflight and go to the receiver tab, it shows that there is no receiver input. However, when I arm and use the controls, everything works as expected, so the Naze is getting and interpreting receiver input correctly, just not showing it in Cleanflight. Also, on motor port 1, the signal pin has a significantly lower voltage than the other motor signal pins, and the motor connected to that pin doesn't run.
Anyone have any ideas what might be causing these? Could I (god forbid) be in need of a new FC?
I'm using an FrSky XSR with a Turnigy 9X v2 and a FrSky XJT module.
