Reciver setup problem
tgregi
Hi im totaly new into drones and i bought eachine racer 130
I bought version without reciver becose i have turnigy 9x and frsky V8FR2 reciver (i know its bit big but im waiting for something smaller, but for start its fine for me)
I have bind reciver with radio with no problem, while its connected to naze. after connecting to pc i have no data recive in cleanflight in reciver section.
I dont know if there is problem in my radio settings or clean flight settings or i have some issues in connection between reciver and naze.
I was looking for two hours to find some tutorial how to do it step by step for total noobies like me but found nothing helpful.
I will appreciate any help. Thanks
ElectriSean
Eternal Student
You need to connect one signal wire per channel between the naze and the Rx and select RX_PARALLEL_PWM as the receiver mode.
PsyBorg
Wake up! Time to fly!
There are two places that must be set to PWM mode. One is on the config tab and the other is in the receiver tab if I remember correctly. Both pages have to be saved after the changes before going to the next page other wise it sometimes forgets.
ElectriSean
Eternal Student
There is only one, it's just different between Betaflight and Cleanflight, so definitely confusing.
tgregi said:
I have connect it through multiple wires (+ - 1,2,3,4 ch) swich to RX_PARRALLEL_PWM and still nothing
Are you sure you are connecting the signal pin on the Rx? Is the battery plugged in, Rx getting power?
tgregi said:
So i must connect all 6 channels? I thougt it can be done only with one signal wire
It can be done with 1 wire if the Rx supports PPM or serial, I don't believe yours does.
