Tactical Ex
Mind control? Sweet.... Does anyone remember what motors Bixler is using on the Kraken? I'm sure it's in the vids somewhere.
Also, do any of you fly both the tractor and the pusher Versa? What is the difference in flight characterfishsticks? I have only built the blunt nose pusher.
And last question, does he use a counter rotating prop on one side? I don't believe he does, but if someone knows??????
I have a tractor and a pusher blunt nose versa and they behave mostly the same with the exception of that the tractor can maintain slower speeds with less yaw oscillation and it is less sensitive to CG issues. The pusher is nearly impossible to slow down to land, I usually have to abort my first landing attempt to drain some speed. This is just my plane though, yes just one, because I use a swappable conversion pod that lets me switch between pusher and tractor.
