Raptortech
Foam Addict
For gluing XPS (pink insulation foam) Gorilla Glue is my favorite. It fills the gaps nicely, sands well, and is super strong!
I'm considering just buying a bunch of polyester resin. I'm going to need it when I fiberglass the thing, so is there any huge reason anybody can think of for why I shouldn't use it to attach formers to my fuse frame?
Doesn't polyester resin melt foam?
I have no idea, does it? If that's the case, I'm going to run into an issue when it's time to glass it...
In short, yes... it does. There are some foams that are safe for polyester resin, but not the stuff most of us use.
this is a monster build ,subscribed. Oh and what 3d printer do you have?
Well that's unfortunate. I guess I'm gonna have to use epoxy resin.
I've had VERY good success with 30-minute epoxy thinned 50:50 with Isopropyl Alcohol. thins down to a very light syrup viscosity, wets very nice and gives plenty of working time before it thickens or gums up. wait a day and follow with WBPU + Talc (also mixed 50:50 by volume) to fill the weave. Wait a day and sand down to the epoxy and you should have a smooth surface to work from (if you hit the epoxy layer and the weave is still pronounced, run another layer of the WBPU slurry, and sand again).
Not quick, but cheap and everything but the glass cloth can be found at Lowes . . . well, even the glass if you want the really heavy stuff.
If they are fixed, and if you have any AOA when the fuse is strapped to the roof you can get aerodynamic forces on the stab and put a lot of stress on the fuse.
Yeah that could be ugly. I plan on making the horizontal stabilizer removable. I think I'm gonna make them slide into place on a couple sections of PVC pipe, like the wing sections. The rudder is going to be permanently installed, so I'll just have to make sure I line it up as perfectly as possible. I know I mentioned taking the highway earlier, but I wouldn't take it that fast. I'm only about 30 minutes north of Malvern, so I'll take the back roads and limit myself to 45-50mph.
I didn't get as much done tonight as I would have liked, but I gotta get some sleep.
I've got 2 more formers to go, and I'm gonna shape the nose from a block of stacked foam.
I'm gonna plank the fuselage using 1/4" strips of foam. I've been cutting the strips using the setup I showed a few pages back.
