Grifflyer
WWII fanatic
Looks Awesome!Progress, got the servos in, just gotta do the linkages. And wire up an esc and bec. View attachment 148201 View attachment 148202 View attachment 148203
How did you build the skis, they look big, almost the size of floatsOk, starting on some landing gear. Somewhat copying my mount I did on the AN-2 , recesses into the foam and it just has a slot in it and is set at a 30 degree angle forward. Wire is bent into a square and friction fit into the slot and then when I add the skis the rear legs wire is just a smaller square and slides in after the front leg. Really I don't need another set of skis put together I would be able to just swap them over from the AN-2 in a matter of seconds but I do have another set of skis so I just need to bend some wires.
Basically some plywood and foam . I will have to dig back and see if I can find the build pictures.How did you build the skis, they look big, almost the size of floats
Do you have plans for the skis? Looks awesomeOk so Annie has her skis on and Shrubby is now fitted with some also
View attachment 148285 View attachment 148286 View attachment 148287 View attachment 148288
I will post pictures but no real plans but they are very simple to do.Do you have plans for the skis? Looks awesome
Yep, I think my front wire top marks were at 25mm apart and 20mm tall and on the rear wire 20mm apart and 15mm tall so it fits into the front one.So then the front and rear wire struts slot into the same pocket in the fuse, unlike two separate pockets for the FT floats?
As you see in the last picture (white skis) that's how I take it off in spring, front wire stays on and throw the wheels on.So then the front and rear wire struts slot into the same pocket in the fuse, unlike two separate pockets for the FT floats?
Camera angle was much better, great flight!!
If it's tip stalling try adding some vortex generators or moving the battery forward a little bit.
Wow, she was surprisingly quick! Nice flight!Shrubby hits the skies again and with some color now, I think it might be faster to
Just a little overkill on motorWow, she was surprisingly quick! Nice flight!
