Seems a little odd to me that a clipped-wing cub would have a pressure cowl, but you made it look good.
I am just seeing this thread and am in the middle of building a Sig 1/4 cub myself. You may want to check out this website thecubden.org as he has some methods for reinforcing the fuse when you cut out the supports to install a door. If you don't reinforce the frame around the door area it will be a weak spot during flight, but it doesn't look to be too hard to upgrade with his instruction, or just be really gentle when flying...
Absolutely gorgeous work, man!The front seat is done minus painting the frame black. The seat back slides over the frame.
Ya, I have a build thread over at RCG. Sig1/4 Scale cub electric conversion build thread.
I also have a completed build thread for the Sig 1/4 scales floats that are going on this plane. I made some modifications on the floats, so they don't look super scale, but will be very functional.
I'm actually addressing the access door issue right now and decided not to do a scale door but sort of a half door/access so I wont need to reinforce the fuse as I plan on leaving the front part where the door would go attached to the formers. It may not be scale but it will be functional and easy to build. Hopefully in the next few days I will get my idea posted on the build thread and easier to understand. I just need enough room to get two 5s batteries (10s in series) in there on a battery tray very similar to your battery tray idea.
My first time in Alaska for work and I had a great time as it was summer and light all the time. I think the 10s power 160 system will work great on the Cub with floats and would be a 3d plane without floats!
