PoorManRC
Back. Full throttle is pretty powerful on my plane, maybe overpowered for its size. I have to give it some altitude and line it up good for straight shots,cause it's fast and it gets touchier as the velocity of air over the control surfaces grows. Good thing is it's got a great speed envelope so I could fly it in a gym if I stuck to slow high alpha. Your Cub should be much more of a no brainer to keep in the air, but still quite agile and capable of some basic aerobatics. I'm not sure what throttle you want to launch at for the Cub but if I don't have to crank a plane to full to get it to launch I generally don't.
......... I'm doing the slow, dramatic Throttle Up, for a SCALE looking Takeoff! 😉
You've seen my trick of sanding all the Leading Edges round and smooth, then "painting" them with White Gorilla Glue to add rigidity, right?
In my case (so far), it's been purely aesthetic...
In YOUR case, it might add high speed stability, by eliminating the Turbulence caused by those FLAT or even CONCAVE L.E.s.....
Might at least be worth a try! 😉
I'm going to go FLY NOW!!! 😲
