Put the motor box/battery tray in, I did some small mods to the nose side vents and swept them back a little for a more custom profile
I didn't mean to have the spinner stuffed under the cowl, but I like the look of it. I didn't take into account where the backing plate sits once installed, I just measured from the bottom of the prop shaft to the firewall, but it turned out nice
This is a 9 " prop on here which may be the smallest I would go. It is a 9x7 which should go nice for a 3s or even 4s would be better. I think I might do the maiden on a 10x45 though, just to keep it docile on the first flight, land it so it will fly again then step it up.
With the motor and battery installed as it sits it balances at around 3/4 - 1" back from the LE. This is as far forward that a battery will go so if I even put a up to 5450mah in I still have lots of room to move it back. The drawn lines on top of the nose are where I will be putting the next phase of the turtle deck construction, it will pop up at a taper to 3/4" above the existing cowl and transition into the hatch. First i will be finishing off the bottom of the nose and moving up and back form there
