Here are some pictures of the finished quad. I originally mounted the camera gimbal with rubber vibration dampeners, but I switched to wire ropes which so far seem to work better. Contrary to earlier speculation about whether the quad would balance with the battery in the back, the situation is the opposite. With a 2200 mAh for flight and a 500 mAh for the gimbal and fpv you still have to place the battery half off the end of the frame to achieve balance. I'm looking in to getting some larger batteries like a 4000 or 5000 mAh so it balances easier.
I have spent a long time trying to completely remove vibrations/jello from my video and I'm still not sure if I'm done. I have yet to try out my FPV setup, but I put together a small rig to hold the camera and TX. When not in use the rig rotates 90 degrees, laying the tall TX down and facing the camera up. Altogether the quad flies great, although there is still some tuning to be done in the gimbal and FC to make the experience a little better.
![topview.jpg topview.jpg](https://ftforumx2.s3.amazonaws.com/2015/01/88135_3094ee8a3915cf775527de725cd9339d_thumb.jpg)
![Closeup.jpg Closeup.jpg](https://ftforumx2.s3.amazonaws.com/2015/01/88138_959fafc9af896577bfd230884da59397_thumb.jpg)
