Hello everybody. A few months ago I built a large quadcopter (680mm) capable of carrying a large camera gimbal as a project for my last year in highschool. The project was a great success and I ended up with a very stable, gentle flying quadcopter. At the same time I learned what was good and bad with the design in terms of how I wanted to fly. Even after downgrading to a smaller GoPro gimbal some of the problems I faced were: trouble mounting hardware on a small body, too large of a size even when folded, and exposed electronics. This first quad served me well, but now it's time to move on.
After reading a post by ananas1301 about his CineFold quadcopter I was deeply inspired to build a very similar design with a focus on aerial photography and portability. With my budget and resources, instead of carbon fiber and aluminum I will be using 1/8" plywood, 1/2" square wood dowels, and plexiglass.
After measuring my electronics I determined that a 500 size quad was the best size. I will be recycling the same electronics from my first quad for this build with the exception of the FC and new FPV gear. I am swapping out my Multiwii Pro with GPS to simplify the build and focus on the flying.
Electronics:
-4 X DT750 motor
-4 X 1147 props
-Q-Brain 4 X 25A ESC
-New MW Flip 1.5 FC
-Turnigy 9X receiver
-Homemade gimbal
-2200 mAH battery
-New Skyzone Plug and Play 200 FPV Set
-New Quanum FPV goggles
Based on the size of my electronics and ananas1301's design, I planned the frame in Sketchup. For a little fun I brought my plans into a rendering program to get some realistic images:
Folded into a small profile
Here is the gimbal and GoPro I will be attaching later on:
I printed out the plans for use as templates for cutting the plywood. Even with a new scroll saw I got for Christmas
cutting out every hole in the frame took a good amount of time. I am a little more inaccurate and create more chipping on the scroll saw than I do with a hand coping saw, but I attribute this to my newbie scroll sawing experience.
Electronics:
-4 X DT750 motor
-4 X 1147 props
-New MW Flip 1.5 FC
-Homemade gimbal
-2200 mAH battery
