Too true. If you will note, I did not conceal anything. And you will see I am about to do that again...
Time for a little heart to heart. I wanted to like this model in EVERY way and I'll admit that I was hesitant to really bash on this kit. I've come to one of the most critical parts and I'm just floored about how this goes together and its just not entirely right. I will underscore here that
what I am about to outline is very OCD of me and pretty much 99.9% of the rest of you will not care.
Starting off here, I'm showing that the motor box built as-is DOES NOT mount using the laser-cut holes in the firewall. Those are for the glow motor mounts. With that out of the way, this then becomes a custom install as there are ZERO instructions for measurement, placement, or even how to fasten the box to the firewall.
So, placing the motor box with the center line of the motor on the horizontal reference line on the firewall, you can see that the center of the motor shaft is about 3 mm too low. This is because the cowl is touching the frame of the motor box. What this does is make the line for the cowl have a little bit of a wrinkle... I'll outline this later when I present the solution. THIS MOUNTING WILL WORK! Its just 3mm from perfect... and it bugs me.
Enter the
adjustable motor mount for medium motors from Tower Hobby. Sure, I had to spend $25 on a motor mount, sure I had to drill and countersink new holes for this particular motor... but 3mm is worth it... trust me. This little doodad can be extended and retracted for a variety of lengths. You can also add in a bit of up or down angle thrust. Right and left you can still do with washers if you want to. Our firewall has right built-in.
The next few pictures show you just how bulky the motor box is by comparison. You can even see where I shaved off the top corners of the motor box to get it to sit right.
I installed using the same method... center line of the motor on the horizontal reference line. I then used a square on the vertical center line going straight out to where the tip of the motor was meeting the square. This meant that the mount was slightly offset. but the tip of the motor would be dead center at the nose. You can also see in this shot that there is a little bracket for you to place your ESC as well and includes a cable tie to keep it secure.
Ok, so here is the money shot... see that even transition where the red meets the white part of the cowl? Yeah, that is nice now. Before it was slightly concave and it really bugged me. Not to mention the spinner is dead on the center of the moulded part of the cowl. And sigh of relief.
Much much much much better. The spinner is nice. I like that it is made FOR electrics and vents air to go over the motor. Nice aluminum back plate too. Perfectly round AND balanced!
So I hope you can forgive this perfectionist. If you build this model you will have to install the electric mount as I did. Keep in mind that this is also the last nail in the coffin here...
This is NOT a beginner airplane.
This is a real shame. The motor mount is what makes this thing fly and not having any instructions, reference lines, or even pre-cut holes for the mounting... just wow. It's a deal breaker. I will also say that the way I did it... took all of 5 minutes. It is not hard to do but can be intimidating if you have never had to do it before.
