@buzzbomb - It is great to get some runs on the board!
well, things don't always go to plan - after a good start, I over-sprayed the side panels and the paper lifted off the FB, and with that, I have decided to re-cut the side panels using a slightly stiffer FB that is available here - it will be will a tad more robust!
I did, however, manage to make the softened 'master class' underside of the tail section which in the standard plan is a box section - it turned out sweet - now I have both of the orange sections to be able to finalise the fuse - I will trim the vertical stabiliser down to match - I found the FB plan is not quite to scale in the back end!
