AwesomeWe have maiden video. I have more to say, but I'll throw the video up first.
Awesome video buddy you really did her justice. Happy forth of July to you all.We have maiden video. I have more to say, but I'll throw the video up first.
Second video is marked privateThis one actually flies!!! It only took two tries but I love it. This one is actually the test plane and I learned a lot. The next one will incorporate all the improvements.
Bungee launching the Spit to get a great launch every time.
Well that's pretty cool, a launcher. I like that the plane is low and at speed, so if thing go wrong, it won't fall far. I would have loved that when I was first learning to fly. The hand launch (me doing it) was the most nerve racking part. I felt it put me behind before I even got started.This one actually flies!!! It only took two tries but I love it. This one is actually the test plane and I learned a lot. The next one will incorporate all the improvements.
Bungee launching the Spit to get a great launch every time. (It should be public now...sorry u tube noob
@Marty72 - awesome maiden - your right she flies well with all that power - I think mine is slightly underpowered!
Great maiden! You’ve got a nice flying field as well.We have maiden video. I have more to say, but I'll throw the video up first.
It is a bit more specific to fit the skins together on a MS build for sure. I find that if the cuts are close enough some final sanding for fit and finish is usually required. Be sure to be aware of the grain direction on the molded pieces as well. The grain of a sheet runs lengthwise on a fresh sheet. So this means that it molds smoother if the curve arc is perpendicular to the grain for an easier fit and smooth panelI have been flying both the my Spitfires (identical airframe) but with different motor and props for a a couple of weeks now. I really don't enjoy the C pack motor (spec) much anymore. The Rimfire 3536 1200 w/ 10x7 is just so much more fun.
I'm also building the Master Spitfire right now. I've had one set back so far, the wing alignment and wing tips didn't come out right (heavily crinkled after gluing), so I made new wings as I couldn't stand to proceed they way they were. (yes, they would work fine, but I enjoy doing it right if I can). I believe Josh is better at pointing out the build pitfalls than John is, I found a few pitfall (builder mistakes, ie me) in the build and I'm sure I'm not alone. I'm about half way through it, I expect to encounter at least one more rework as that's the way a complicated build like this goes. I think scratch builds are harder at the Master's level do to the precise nature of the build, if you don't cut the templates and the foam just right, things won't go together right. Where as the "regular" level, I feel there is a lot more leeway on the foam cutout.
