So I have just recently built a spitfire from the speed build kit, went to go give it the maiden flight and of course something goes wrong, the motor (SUPPO 2208/14 1450KV BRUSHLESS MOTOR) will start up and go up to about 2/3 throttle, once it goes any higher it will suddenly stop and create this high pitched sound. Now I have tested to see when this happens and for some reason it literally only happens when the power pod is in the plane. Outside of the plane it goes up to full throttle and everything is fine, once it is in the plane is when it has the issue. Now I thought maybe for some reason the prop was hitting the nose but there is more than enough space between the two so I am at a complete loss. Has this happened to anyone else or does anyone have an idea as to what this might be?
