I got my new ESCs from RTFQuads on Monday, less than a week after ordering, so I have no complaints about this particular customer service experience. There is a known issue with these ESCs and Cleanflight with Oneshot, where the motors "chirp" at zero throttle. This is fixed by setting min_command=1000, max_throttle=2000, then recalibrate ESC's, then set min_command=960.
These ESCs come from RTFQuads pre-flashed with BLHeli 13.1--the latest version. The BLHeli bootloader is pre-installed, so you can flash and configure the ESCs via the signal wire and the BLHeli Suite app. Lovely. The ZTW Spider ESCs I originally chose had no bootloader installed, which would have made flashing them much more difficult. Lesson learned: only bootloader-pre-flashed ESCs for me from now on!
ESCs installed. Signal wires shortened. The product page for the ESCs says they have switching BECs, so I pulled the power pin on three of them.
Motor wires carefully wrapped. It was a huge pain in the butt, but boy it really looks lovely. The arms have holes for a zip tie, which seems like a good idea given how low the props are on these 2204 motors.
I also decided to add a zip tie to the motor wires at the ESC, again, just to secure the wires firmly down against the arm, to keep them from straying too close to the prop.
I want to give credit to Bruce at RCModelReviews for this idea of how to hold up the antennas. Zip ties. Trim to length. Then...
Place the antennas against them and shrink wrap. This holds them up in a good angle for diversity, but still allows them to bend out of the way in a crash. If the angle is not quite 45 degrees, just bend the zip ties a bit.
