Might be something you are interested in, check it out...
It's a series of three short vids but I figured since you like to build a lot you might benefit from it. Each vid will put you into the next in the end screen.
I printed out the pieces last night but it turns out they are for a mini stang Will still be building a regular sized mustang this weekend, though it won't have a 3d printed canopy.
today I went out with the big mustang, the result has been disappointing it costs a lot to go straight after several strokes
so come to retire and return to the mini scale trying the new Grifflyer
R.I.P.
Some build and finished pics of my full size. Speed wing, flaps, airfoiled tail, removable canopy for access to the electronics. Propdrive 2836 2200KV with a 7X5.5 prop with 60 amp ESC and 4s batterys. 85 MPH View attachment 152981
I put my servos under the rear canopy. @Sero I like the foamboard canopy you did! And btw, I'm using 9g servos on the tail and ailerons, plus a 1500mah 2s or 1000mah 3s (they both weigh the same.)
My Christmas gift finally showed up this should make cutting out planes a little faster. Its a cnc needle cutter so no more tracing out paper templates.
I was looking at that and I think I screwed up , brain fade, I think it is double of what it is suppose to be. It's not getting changed now so we will see how it flies.
I usually just shim the motor with gift cards to get the different angles. Also shimming works better if you configure the mounting holes in a X pattern rather than the + pattern that FT uses on their power pods. This doesn't apply to the minis, too small for the above IMO.
Mustair it is. But I have a comment, either you are rushing the cuts and trying to do it in one swipe or you need some sharper blades, or both Even with my sharp blade I will take 2 to 3 passes to complete the cut .
Small step closer, controls are now all in and hatch is complete with magnets. With the weather I am in no rush plus now with the new Jumper T16, I am waiting on 2 different orders of 6 ch rx's , kind of nice not being locked into one protocol . 3 of each coming, $10.00 each delivered
Small step closer, controls are now all in and hatch is complete with magnets. With the weather I am in no rush plus now with the new Jumper T16, I am waiting on 2 different orders of 6 ch rx's , kind of nice not being locked into one protocol . 3 of each coming, $10.00 each delivered View attachment 154139View attachment 154140
