An Arrow doent make sense if you have no bow. So this thing is a great addition to your arrow, although its flying caracteristics are the complete opposite. Its so slow and gentle that you can chase it by running or fly a few inches low over the ground, but it has enouth power for unlimited vertical. The pusher trainer layout makes it a great belly lander that can even take off on its belly and make curves on the flying field.. It takes batterys from 3s 600 up to 3s 1200 and is great with an FPV tailcam. And all you need is an FT Arrow and one sheet of foam. Its almost like an FT Explorer, but with the Arrow as a wing. Here are a few pictures:
The tail cam that is a great counterweight for big batterys
The tail has one elevator servo. The elevons on the arrow act as flaperons here.
Thats how the inside of the fuse looks: more space for stuff, BBQ skewers for rubberbands and bended foam to reduce drag and noise. Its still very noisy, especially with the two bladed prop.
You also need to do a couple mods to your arrow. I made the center pod bigger to get more space and it gives the plane with the fuse a very nice looking cockpit.
I also added a piece of foam to the bottom to get moe stability and to hold the wing in place. There is also a small hatch for the wires of battery and elevator and I added skewers to the leading and trailng edge so that the rubberbands dont destroy the foam. You also dont need the up elevator on a flying wing in plane mode so the wings cteate more lift and the CG shifts back right to the trailing edge where the firewall sits.
More updates and videos will follow soon. How do you like this addition? Also show me your Arrow mods.
