Ketchup
4s mini mustang
I barely even saw the censoring lol.Woah Profanity!!!!
Woah Profanity!!!!
FixedI barely even saw the censoring lol.
I was joking!Fixed
OkiI was joking!
We both were lol
Whoops I guess not. I didn't read the description all the way until after I postedInteresting... but someone else already beat you to it
but I want it scale..... I already have a really cool idea for it... shouldn't be too hard either to build.....will be kinda like master series corsair.....with standard ft wingsU know you could probubly take the ft commuter then change it to low wing instead to make it look like the commanche
@Whit Armstrong @The Hangarhi @GrizWiz @mackaiver @whackflyer @PlanesAndThings @Quinnyperks
can someone give me the dimensions for the standard ft power pod....
Once I have those the formers will be done... for the Comanche
and then the wingsformers done now for the skins
yea my Inkscape is not working.... maybe once I have all the design done... I will try use fusion 360... or someone with more experience could do thatYou can import the pdf plans of any plane into Inkscape, or convert them to png and import them into Fusion 360. In fusion 360, you can calibrate it to the scale. In Inkscape, they'll be the correct size. You can then design your plane around it.
Sleepinghey where is everybody...????
In Fusion 360, it's really easy to go back and make changes to the model, so you could go ahead and design the model, even if you don't know the dimensions of the power pod, and put it in later.yea my Inkscape is not working.... maybe once I have all the design done... I will try use fusion 360... or someone with more experience could do that
