TL;DR: This design was cool but not the best, might do XB-70 V2: Electric Boogaloo.
Time to bring this project back from the dead.
During my first year at college I've been studying to be an Aerospace Engineer. I know a bit more about aircraft design than I did when I started this project. Combined with recognising the various shortcomings of the original design, I've got to thinking about what I could do better.
The original suffered from being heavy, overbuilt, and underpowered. These issues stemmed from gross underestimation of the final weight, structural inefficiency / overbuilding, excessive ducting losses, excessive wiring losses, battery voltage drop, and more. The result was a plane which had to be flown hot and fast while struggling to do so, causing lots of stress on the components and the pilot. Here's what I would change in a version 2 to mediate that:
Wings
The wings were a simple flat-bottom delta with an eyeballed trapezoidal cross-section and < 3% thickness. There was no intentional washout added, although the wings conveniently warped a couple of degrees in storage and retained some washout after de-warping. Moving to a thicker aerofoil would generally increase the lift at a given angle of attack, leading to slower flight speeds. Thicker wings are also easier to deal with structurally and may resist twisting and deformation in storage. It may be prudent to move to an actual aerofoil instead of an eyeballed trapezoid for an improvement in lift and drag. Intentional washout is also a must for stability reasons.
Wiring
The main power wiring to and from the ESCs is undersized on the battery end and oversized on the motor end, resulting in electrical and mass inefficiency. They're also solid-core, which is a pain to deal with. Moving to properly sized stranded core could decrease wiring losses and mass while being easier to work with. The same can be said of the servo extensions, although to a lesser degree. Having a dedicated servo extension crimping tool and a roll of standard servo wire is probably better over soldering whatever wire I could find in the scrap bin to the two ends of an existing servo extension.
Batteries
In an effort to economize legal tender, I opted to get another set of the batteries I had for my RC truck instead of get an entirely new set of batteries. This meant that one of the pairs was a bit old and had been abused previously. Combine that with the high-discharge torture I put them through and you've got a nice voltage drop under load. Higher quality batteries of the same capacity weigh less (due to not being hardcase) and have higher discharge ratings. Another idea is to add an extra cell to combat the wiring inefficiency, add more effective capacity, and give a bit more "oomph" for takeoff. Whether the motors will be happy with that is a different story.
Ducting
A combination of voltage sag under load and ducting inefficiencies led to a near halving of thrust from on the test stand to installed in the plane. Some thrust was recovered on later flights by massively enlarging the landing gear / cheater holes and adding some directing plenums inside the duct. Adding larger bellmouths or properly converging the duct into the fan's mouth instead of the current airbox setup could lead to greater static thrust. I have also wanted to investigate the effect of the geometry of the thrust tube on static thrust, not just the outlet size in terms of fan swept area.
Construction
The attachment of the front fuselage to the main fuselage was so strong that it did not need to be repaired even after the crash on flight 2, during which it visibly flexed to a ridiculous extent. This tells me it is quite overbuilt, which is a bunch of excess mass that isn't needed. This is true of other parts of the craft, such as all of the sheeting of the fuselage and wings. There is great potential for weight reduction in the use of alternate materials - I'm thinking about thinner sheeting like balsa and depron as well as some techniques like hot-wire. The spars attaching the four main parts and the methods of locking those parts in place are also not ideal from a structural or aesthetic perspective.
Aesthetics
It looks good from afar, but far from good. There are numerous gaps in the foam sheeting, rough edges, and wrinkles. It's beneficial in that it gives me less qualms about the potential of crashing it and ruining what would be a perfect airplane but detrimental in that it's a bit of drag and aerodynamic inconsistency.
These are just the broad topics in the bits that I'd like to change. Will I actually get to changing them? Well, I've got a long summer with not much to do at the moment, so we'll see. This time around, I make no promises.
-------------------- XB-70 V2: More Power, More Lift, More Engineering. --------------------
