Amazing video buddy!Been holding this close to me for a while and don’t know why, think it’s time that I present to you my best FPV camera video to date, enjoy!
Too bad about the first crashes, but your repairs really make it look almost new! Good luck on fixing it again.@Marty72 this post is dedicated to you.
As some of you might know I recently built the Master Series Spitfire. I found that the build itself is a little more complicated than Master Series Corsair which I have built, but the outcome is amazing, especially if you add some decals.
View attachment 173352 View attachment 173353 View attachment 173354
Unfortunately on the maiden the plane didn't fly well, on my first launch I had an issue with an aileron control horn that broke and I had to emergency land it with a lot of luck no damage was caused. On my second launch the plane was out of balance and seemed to be very nose heavy something that made it hard to trim the plane, regardless was no fun because I always had to hold the up elevator to hold the plane from nose diving into the ground. Somehow I landed again I managed to land the plane with no damage considering the circumstances. After fixing the balance issue I launched the plane for the 3rd time, this time around the plane flew better. A much less up elevator was needed to keep the nose from diving so a little trim should fix the issue, I climbed 3 mistakes high and started trimming out the plane. After a bit of trim the plane was a lot more stable and easy to control, but still stayed a handful for the less experienced pilot. The reason why I am saying that is because the wing airfoil that has no under camber wing tips like the Spitfire David designed does; makes the plane drop a wing tip on you on a sharp turn at lower airspeeds. This is something to watch for and be prepared for because an inexperienced pilot can easily freak out and lose control causing the plane to spin to the ground and crash. A good tip to delay a tip stall from happening and helping you get out of it is to turn your rudder towards the opposite wing from that which is experiencing the stall, then apply some opposite aileron input to level out the plane.
Here is a highlight video for the maiden flight.
Anyhow from the first maiden day the plane came back with a few bumps and bruises but all were fairly easy to repair. The next time I took it out the plane flew ehhh and upon a hard cartwheel crash the outcomes were a little less on the bright side as opposed to my previous outing with it.
View attachment 173355 View attachment 173356
Ok so this is bad but you all know me, I don't just RIP a plane because it needs surgery, so I put on my surgery gloves and got to work. The crash broke my wing in half and I guess it's mainly because the plywood spar from the original design was replaced with a 5mm balsa spar because I have a hard time finding and cutting out plywood. The first thing I did was glue the two wing halves back together and for extra strength I also added a small piece of carbon fiber rod that I had laying around. Once the wing was back in one piece I moved on to the fuselage which needed a whole lot more work to fix. The fuselage was ripped into 3 pieces so I was really pondering how I should put it back together and what would be the best way to re-enforce it. After running through all the ideas that I had I decided to re-enforce the sides of the fuselage with a thin 2mm balsa sheet, which was a good idea. It helped stop the hot glue from dripping all over the fuselage since it was glued on the inside and also helped put more pressure on the break point.
Next up was the entire motor pod area which also broke off and as easy as it seemed to fix, actually required more awareness which I didn't put into it. I had to make sure to get the motor aligned to the rest of the fuselage but since I wasn't thoughtful about it I ended up gluing it on an offside. Alright well with that out of the way the last thing to do was glue the wings back together with the fuselage. This was a little harder than I thought it would be because I found myself having to trim the sides of the fuselage for the wings to sit straight with the horizontal stabilizer. Once I got the wings to sit leveled with horizontal stabilizer gluing them into place was easy and went quite well.
View attachment 173357 View attachment 173358
The plane was repaired and ready for a re-maiden, and I was eager to give it another go. Without wasting time the first day I could I went to the field and took the Master Series Spitfire with me for another maiden. This maiden didn't go well either and after a short sketchy circuit around the field ended in a crash in which I broke the firewall. So now I have a new issue, one which I don't know how to fix or actually to be more exact, I don't know what would be the best way to fix. @Splinter189 any recommendations?
To sum up considering Davd's design of the Spitfire is definitely one of my favorite FT models to fly, I think this one deserves a second chance, so I will rebuild this if I can't repair it once again, because I don't feel like I had the chance to really experience a decent flight with it yet.
Nooo! Gear failures are THE WORST!I have never felt so upset in the hobby as I did today! I finally got my daughter interested in flying and built her a new TT to fly this morning after my shift, considering I can’t go to sleep cause my wife is at work. I got to the field pumped of excitement just waiting to give the sticks on the new TT. But then all just went side ways up to the point where I had to give up trying to fix issues at the field and go home. The motor connector broke lose one servo that I used was stripped and didn’t show up at the office testing last night. She obviously doesn’t want to go back to the field and I am supper disappointed in myself and sad to cry from the situation .
Thanks!Amazing video buddy!
This one is actually mocking me cause I am clueless as to what is the best way to repair this was hoping @Splinter189 would give me his two cents.Too bad about the first crashes, but your repairs really make it look almost new! Good luck on fixing it again.
True it’s even worse than a crash because on a crash you still had some fun .Nooo! Gear failures are THE WORST!
She did get back to the field the next day actually which was great. I still haven’t posted about it cause I didn’t get around to it but I will over the next few days on this thread: https://forum.flitetest.com/index.php?threads/teaching-my-children-to-fly-the-diary.58161/ which I suggest you check out for ideas on training kids. I would also recommend the TT as a trainer easy to build, fly and repair .Sorry to hear your daughters fly day didn't happen. Don't beat yourself up over it. I am sure you will get her back out there. Having two small daughters myself I feel for you. I am also hoping to build something for my oldest daughter. All she asks since I built my p40 is when daddy is going to make her a plane to fly too?! I'm thinking a FB glider or a champ because she's only gonna be 5 here in October. Anyway hopefully you get your own daughter back to the field so she can experience the fun of RC aircraft with her dad. I'm sure she'll love it!
Haven’t built a TT yet but the champ is a solid plane! It flies almost hands off and can take quite a beating.Sorry to hear your daughters fly day didn't happen. Don't beat yourself up over it. I am sure you will get her back out there. Having two small daughters myself I feel for you. I am also hoping to build something for my oldest daughter. All she asks since I built my p40 is when daddy is going to make her a plane to fly too?! I'm thinking a FB glider or a champ because she's only gonna be 5 here in October. Anyway hopefully you get your own daughter back to the field so she can experience the fun of RC aircraft with her dad. I'm sure she'll love it!
Is it a fixed power pod? If you can get a close-up I might have some ideas...Thanks!
Exactly!True it’s even worse than a crash because on a crash you still had some fun .
Yeah it’s fixed but not only that you don’t really have access to it.Is it a fixed power pod? If you can get a close-up I might have some ideas...
That’s a tough one! I’m assuming it’s on a power pod that you glued in similar to the Corsair, right? Any way you could use a knife to cut the glue and pull it out?Yeah it’s fixed but not only that you don’t really have access to it.
View attachment 173905 View attachment 173906
The yeah it’s glued in from both sides and on my last repair I put extra glue . The Corsair power pod can actually be remove and replaced. The only thing I can think of is cutting off the nose and I am not really up for that ATM to much going on right here.That’s a tough one! I’m assuming it’s on a power pod that you glued in similar to the Corsair, right? Any way you could use a knife to cut the glue and pull it out?
Wish I could! It was just one of those times where I didn’t use an X mount .A repair like that nose might be easier if you can unscrew the motor and just glue another fire wall right to the old one.
Too bad about the edge, but I’m glad you were able to fix the spitfire!@The Hangar I am bumped out that I can't take my Edge 540 to the field tomorrow because the cloest containing it is also covered in plastic wraping so decided I try repair the Master Series Spitfire. What I did was heat up a table knife and then used that to get the hot glue to melt I did that a few times untile most of the power pod came loose. I then repeated the same proccess with anything that was left inside the fuselage.
View attachment 174011 View attachment 174013
And this is the end result.
You mean break it again! Which is exactly what happened on today’s maiden, guess I am doing something wrong .Too bad about the edge, but I’m glad you were able to fix the spitfire!
Lol most of the time I end up going to the field alone . I actually thought I’d have company this morning but going alone . I was really hoping to get out more people to the field but that ain’t working as planned, Covid19 and stuff of course ain’t helping much. As of now we might be going into lockdown again .I feel like this could be the start of 'RC-club' Mayan!
