Build is mostly done, just waiting on the running gear to show up. Decided to go with the FT "C" pack motor. Once the electronics are installed I'll knock out all of the final stuff like wing tie downs. Also need to build a power pod or reinforce the nose (permanently). I think I may externally mount the tail servos near the back, I should have plenty of weight up front with 3 or 4s batteries. Given the extra power I may add some carbon supports for the rudder/stabilizer too. I knew I should have added a BBQ skewer to the rudder before hand
Also, landing gear is a ? for me....90% of my flying with this will likely be in tallish grass so may stick to my plan to skip them.
Glad I knocked out a "tiny trainer" for friends to use (crash) before tackling this. Helped me hone my foam techniques. This came out almost perfectly - the only imperfection is I was holding the rear fuse cap down a little too far (visible just behind the wing). I was too focused on getting the tail area fit without wrinkling the paper/foam. Otherwise it went together great.
Oh, also bc it was discussed before. No way my extra Hitec 9g mini servo would fit in the spar. Too long and tall. I decided not to cut holes for the servos until the blue HK specials show up.
She should fly great!
