BATTLEAXE
In building the internal structure of this Spit, I have some indications of some changes needed, I will have to watch the build vid again. But I have come across a issue with the servo placement for the tail feathers, as is they are supposed to mount to the spine inside the battery box, behind the battery box, with the servo arms up to meet the holes for the pushrods to pass through the bulkhead into the tail section. If you follow that you are better then I cuz I had to think hard while typing lol. Problem is that if I put them in like that the servo arms would have to be cut in half just to swing in the limited room inside the battery box so they don't hit the walls.
Now the solution could go one of two ways...
1. would be to mount the servos upside down and lower the pass through holes in the bulk head, this way the servo arms would sit in the clearance notch at the rear of the battery box cut out about 2/3rds on the bottom so the arms clear the sides of the box, or...
2. mount the servos in a notch i trim out of the spine 90 degrees on their side so the servo arms are set vertical.
Again i will have to watch the video again. I am just looking at foresight trying to predict possible problems. @herbertjalarcon built the Spit already, maybe he has some insight on this
