BATTLEAXE
Got some work done on the Spit over the past couple of nights. This Master Series stuff is definitely a slower process then the original FT models but it is definitely more rewarding in the end. This is where I got to as of last night...
Tonight I installed the servos in the wing and the tail section. Kinda went off the beaten path of following the build vid with a few areas. You can see the former stack for the nose has the plywood glued on for the firewall that the X mount gets screwed to. The only reason I will still use the FB power pod is to tie all the nose sections together for strength and support.
Spent about half hour just forming the outer skin for the tail section. This is one of the areas that I left the build vid behind. Instead of flying the bottom seam the full length of the skin first then sliding the spine in, I only glued the front 3-4" and left the rest open at the seam. This gave me access to slide the spine in while lining up the control rods with the exit tubes and be sure the top of the spine was securely glued tot he skin the full length of the tail. Once the spine was in place then I glued the rest of the seam one section of masking tape at a time till it was full closed up. It all worked out square and straight and finished off nice. The more i build the more I want it done just to see it all together.
