The Talespin Tavern -all things off topic
Battery800
Do you want to be scale or do you want me to dry you up some plans?
Not scale at all. I'm making a performance quadplane. I will need either an stl or a detailed 3 view to make a model with. I'm gonna print a shell and then go over with carbon fiber/glass and fill with spray foam.
I  could suggest the OV10 bronco with whichever tail configuration you like running a "C" power system in the main pod.
Doesn't do low inverted passes really well, the tail drags on the ground.
cyclone3350
I like that suggestion. IDKW, but the only twin boom single engines that came to mind was either the flying Pinto or Mad Max beyond Thunderdome (AKA PL-12 AirTruk). Neither one would be considered a speed demon.
luvmy40
Does anyone know what, specifically this tripod would be used for?
It's lighter than it looks like it would be. The center post is a friction fit with a thumb screw clamp. No rack/gear adjustment. The legs extend independently.
It's a legacy that came with the "new" house.
Thanks!
cyclone3350
Thanks!
If I had to guess, I would say an artist easel. I have something similar, except for the one I have is ancient & made of cast iron. I use it for a drafting table. There should be a part that screws on the top to attach a drawing table to.
Bo123
Thanks!
use it as a sun shade for flying.
Bricks
Thanks!
Anything you would like it to be used as. 😍
Off-topic jes
so ive built a model pacer and am going to do it free flight and want to power it with a super capacitor, im using the motor set up from the hobby zone champ. what would be a good capacitor to power this motor for 10-15 seconds.
Mmmmmmm. Got some stuff at a local swap meet and came in under budget
The VolantRX composite-foam 2 meter glider will be in the air first. Just need to fix a broken end link and throw a radio in. Liking the rigid body compared to my current all foam Surfer 2000. Plus it has a nose motor and folding prop. Should be a much nicer flyer.
The balsa is missing the rudder servo, and I will most likely add a nose motor
Cheers!
Bricks
Cheers!
And you did not spend more to reach your budget????????????????? Sad just SAD your teaching the wrong attitude.
Hondo76251
Thanks!
It almost looks like an old spotlight/stage lamp. Could also be some kind of surveyors tripod.
Sorry, a bit of an older post but I haven't been on in a while. Just catching up, and checking to see what's become of the aviation community and all the new rules 🙃
Matthewdupreez
hahaha same lol
decided to see what's been happening around here after a long year
