Ok plans cleaned up and good chance these will pretty close to final (Assuming all goes well with the next maiden). Figured I would post the latest beta plans in case someone wants to jump start the build.
Power pod uses STD ply firewall, pay attention to the top to get thrust angles right. Rudder is a single layer, elevator needs to go on before the final rudder piece. Fuse gets the paper removed on the inside. Wing gets the paper removed on the bottom half only. I glued the Fuse together with 3M Super 77 (My favorate glue for foam on foam laminating). The wing is glued with hot glue, a line on the leading edge, the trailing edge, just behind the leading edge, one down the middle, and anywhere else it is needed (I put the glue on the bottom half before folding). Be sure to fold and form the wing with all the paper on first before removing paper (makes it easier and straighter)
Files removed, New versions available
