Chuppster
Work has been kicking.my.butt.
Moving along. I managed to get the V-stab and the hatch glassed using my normal method of .75oz. cloth and Sanding sealer/WBPU. They really are the same thing. I used 100-grit sandpaper to sand the edges of the glass overage on the hatch and the glass just trims right off.
View attachment 159467 View attachment 159468 View attachment 159466
I got my motor mount in the mail so I went ahead and checked the plans for thrust angle. No right thrust as far as I can tell from the plans or instructions. There is some down thrust that required me to raise the mounting point of the motor at the firewall by 4mm. I drew a reference line above the center line on the firewall and marked the vertical center. The Great Planes medium brushless motor mount comes with a template for drilling. The top holes were fine but the bottom ones were going to interfere with the stock mounting beams. Thankfully there are additional holes on the mount further down so those holes were utilized. I used blind nuts (also called t-nuts) behind the firewall with 3 washers between the firewall and the mount, only at the top. These washers create the down thrust angle that is called for. I also mounted the cowl ring with a corresponding spacer I had on-hand.
View attachment 159465 View attachment 159464 View attachment 159472 View attachment 159471 View attachment 159470
And then I put on the cowl just to check the look.
The head-on shot above you can see marks made on the mount for the motor. These are for the bolts on the back of the motor to bolt on the motor. They will be drilled and cleaned to make sure there are no metal shavings to get into the motor. Once the motor is on I can then adjust the mount to get the proper distance from the firewall to the prop mount.
Are you comfortable with half of your mounting bolts only being half-attached to your motor mount? I'm assuming you're going to direct mount the motor and not X-mount it correct?
