Using CT6 controller with Sea Duck twin engine Plane. Need Help!
beginner
Hey guys,
Totally new to RC. 1st plane sea duck build. I am using a FlySky CT6 controller(http://www.hobbypartz.com/exrc62tr.html). I have the flaps figured out. I am having issues with getting both the motors to work together. As soon as I connect power the motors keep beeping, when I follow the instructional sea duck video and throw the throttle to full, nothing happens, when I throw throttle to zero, 1 of the motors does the "calibrated" series of beeps while the other motor keeps on beeping. I have left motor talking to channel 4 and right motor talking to channel 3. I have toiled over this for 3 hours and no progress. Maybe some of you use this controller and can help me out.
PS. using the software I mixed both channels to respond simultaneously to throttle up and down but still having issue with motor calibration as above.
Thank you!
Hai-Lee
Old and Bold RC PILOT
#2
You can either set up each ESC in turn or fit a "Y" Harness and program them at the same time.
After doing that fix up the transmitter programming or mixing
