Hello im new to the forum, I was just listening to the podcast and they mentioned one of the challanges I posted on the facebook. Not sure the best place to post this.
The challage is to build a plane that can transition from foward to reverse flight. I do not have the resources to build anything at this time but would like to share a few of my ideas.
1. The use of an rc car speed controller and a sensored motor to give foward and reverse. Props might be a problem but I am not sure how handle that.
2. The use of a moving tray of some sort for pitch control. My thinking is you could mount the battery in some sort of tray on rails. So in effect you would be shifting the cg of the aircraft to control pitch. This would remove the need for elevators. Possibly using a servo as a worm drive or even a pulley system.
3. Possibly using drag flaps in place of a rudder to avoid the problem of changing direction.
These are the main problems I can see and can think of possible work arounds. I think the wings might be a problem aswell. Would love any input on this and ideas on how we can see this happen.
Cheers
Fraser
Cheers
Fraser
