zombiehunter
Hello everyone,
I need some help please. So I just bought the Versacopter 2.0 with power pack E, along with the Naze32 rev6 all from Flitetest. I followed the build video and the other Naze32 rev6 setup video. Everything seamed to go well no issues during build. I Did all the PID tuning as per the video. Set up all the cotrols and I thought I was great. I setup all the props and double checked that everything was on correct. I took it for the maiden flight. I was able to get it hover about 4 feet off the ground no problem. as soon as I rolled to the left the whole quad started to shake slow at first then got faster and faster. I tried to lower the throttle and bring it down but it just flipped upside down and went straight into the ground and the throttle shot up on its own. I guess it was trying to level out, It hit the ground hard, the props exploded, and motors got all chewed up (I was on cement at the time so I can get a level take off). I hit the throttle cut, picked up the pieces, and now i'm back to the drawing board. Only problem is i'm not sure what went wrong. All the props and motors where turning in the correct way. I guess the problem must be something in the PID but if I used the same settings as Josh with the same power pack then how could that be? Any Idea what went wrong? I was in angle mode at the time FYI, Thanks for looking any advice is really appreciated. I have built several quads in the past but this is my first Versacopter and my first Naze32 Rev6 so I'm lost.
