leaded50
I got a 70mm EDF free, since a seaplane jet wsnt possible to get functional as intended without opening up more for air , and then also possibillity for water at intakes.
Found then one plane/spaceship on my "list" was possible would fit this EDF nicely. Yeah, i need som extra intakes/cheater holes than on original rocket version.
Its unusual unique, a very special design that fit me great, when just sitting here medicined anyway waiting for even another operation in approx 14 + days..
Approx 1000 +mm length, a adjusted wingspan from scale to approx 600mm.
Other changes will be fully wheel retracts, not just frontskid, and the two others wheels as on original.
The "wingsides/tail booms" is orginally possible to raise close to vertically for floating in space, with big "flaps" between,and some small elevator surfaces on tail stabilizers.
Here i plan to make the hole booms and the "flaps/ailerons" surfaces rotating together as a deltawing with elevons functionality. Then dont need any servo functions on the elevator parts on tail-booms.
Rudders on the booms, ive not decided about yet. On the original, it has some parts similar to two vertical "things" at end of exhaust port. Perhaps can make some rudders there?
Model needed be made in two parts, where the EDF should fit into front of the rear part. Shape of the fuselage is quite similar to a smaller passenger jet, who do it easyer to build, since could use the experiences from earlyer builds.
Of course, its gonna get a similary of the originalpaint scheme
