speedbirdted
Now is the time that I pull the trigger and build one of these! And the box showed up today so I guess I can't put it off any longer...
This is what I got in the kit. First impressions are WOW the laser cutting is very well done here. Seems like most laser cut kits I run across were either cut slightly misfocused of with too much/too little power, and neither of those conditions shows up here. Everything looks and feels like it'll come out with minimal effort and that's what I like to happen!
It's also not common that I start a build already having everything I need to finish it besides the kit (besides batteries - but those are still in transit) and this is what I'm going to use. The motor is a 1510 and it's probably going to be massively overkill running off of a 12 amp unbranded Banggood-esque speed controller, but hey this is what I had and it'll just make the takeoffs shorter. On a 6x3 the motor easily makes 300g thrust so this should be fun! I also bought one of the receivers they had in stock at Willy Nillies because I didn't have one that would fit. Initially upon seeing it I was concerned because Redcon makes a very similar receiver that is sold on Banggood and I've had bad experiences with them, namely I bought four and three refused to bind. Luckily the one I ordered with the kit worked perfectly.
I also bought some 1.25" wheels. Though I have some 1" wheels on hand as well if those end up looking weird, but I think they'll be fine.
You may wonder why I have 5 servos. Well...
Most of the Eaglets that I've seen built so far have been fairly standard. Nothing wrong with that! But - now that it's been proven to be a very good flying airplane by several independent people I think it's time to get a bit creative and build something more unique.
So I'm going to be doing some alterations to the kit -
Stay tuned. I'm currently in the process of moving house, so there's no chance I'll get this entirely finished in the space of 10 days like I did the Gentle Lady, and don't be surprised if it falls off page 1 for a while at a time...
- Taildragger. Don't have anything against tri gear planes, sure the ground handling is great, but I think this plane would do pretty well with a taildragger setup. It would also cut a little bit of weight out, no big nosewheel. I think I'm going to just use a tail skid, since getting an actual tailwheel to work while this tiny would be torture and I don't want to add any more tail weight than I have to. Hopefully the heavier motor will maintain balance even with no nosewheel, helped by having the main gear moved forward. A taildragger setup also helps my next mod, which is...
- Swappable gear. I am going to build floats for this thing (and claim the first floaty Eaglet because I don't think anyone else has done it?) simply because I flew a UMX Timber off of water and was instantly in love with it, and that plane is about the same size and weight. This will require a little bit of fuselage modification and if I do it right hopefully it won't result in any noticeable weight gain or cg changes. My idea is add a tab setup for the wheels and forward mounting for the floats and then adding a tiny little ply hardpoint where the rear float mounts go, and using a couple of screws to hold those on. The tab in the forward fuselage will either be retained with neodymium magnets or a servo arm acting as a latch. Whichever is lighter and works better.
- Flaps! This is why I have the extra servo. I honestly have a hell of a lot of work to do to figure out how to implement this and do a good job. And before you scream at me about flaperons, I know, and sure I could use them and save myself some headache but separate flaps are a lot cooler. That and from my experiences flaperons make your roll authority kind of disappear, and that is generally considered suboptimal. The way I want to do it is have the aileron servos placed farther out in the wings which will probably require either modifications to the existing ribs or cutting a couple of my own ribs, both of which I can live with. This is to both free up space in the center section of the wing and also move the servos to where the ailerons actually are on the outer portion of the wing instead of them being the whole trailing edge. Emptying the center section of the wing of servos now allows me to install the fifth servo in either one of the spots where the aileron servos are originally supposed to be, or in the center of the wing directly above the fuselage. The first option requires just a simple torque rod to control both flaps at once and is pretty easy to implement as I could just run the torque rod through a brass tube embedded in the trailing edge. The second option requires the control horn to be on the torque rod - harder but still doable, and it removes the visual and physical imbalance that comes from mounting a servo on one side without countering it with a second one. I still have a lot to work out and a lot of studying the kit to do, so I might end up doing something entirely different or if I determine that it would be too heavy and impractical I might skip over this entirely.
Leading edge sheeting. Not sure if I'll do this one or not - it would require shaving down every single wing rib, and while doable it's quite tedious. Especially considering the only reasons I really want to do it is to experiment with mounting VGs on the wing to play around with. The benefit of helping the airfoil maintain its shape has been shown to not matter as I don't think anyone that has built an Eaglet thus far has done this.why'd I think of this?
