Michael9865
About the tail feathers, if you want to steer the tailwheel off the rudder (if you are adding a wheel) you have to either move the rudder back or not have the tailwheel all the way back.
Unless you are flying off pavement all the time, don't add a tailwheel or any mechanism to have one. It adds a significant amount of weight to the aft end and you will have to add 4 to 5x that weight to the nose to offset it.... your all up weight goes up and flight performance suffers. A simple lite ply skid would be your best choice.
Sincerely,
Doug and Becky
WillyNillies.com
I'll second Doug's comment. After building two Willy Nillies kits I'll be looking for ways to lighten the airframe, not add to it. The Eaglet weighs 7 oz, the Skylark 6.9 oz. Neither needed ballast. The goal for the next one is 6 oz. Light is might and every gram you can eliminate on airplanes this small will make it fly better.
Thank you all for your input. I have already decided to forego a steerable tail wheel. I am not sure whether I will opt for a wire or a bamboo skewer skid Like I use on my FT type airplanes. I am so pleased with the ease of building this kit. It is my first balsa build since the mid eighties. (I know I just severely aged myself. LOL!)
