OK, so here's a quick covering progress report. The fuse is pretty much done. While the original covering scheme looks really uncomplicated at this small size the curve radii are nearly impossible to reproduce (at least for me) using strips of covering material. What you see here is my 5th attempt with the white Solarfilm cut at 4 mm for striping. I had to finally call it good and just move on. From 25 feet away you won't be able to tell and if you can then just look the other way.
I'm about 3/4 done with the wing and the larger area of metallic red and black together look amazing. A perfect color combo.
I'm having to stretch every millimeter of SolarFilm metallic red and black as I just don't have any more. No room for errors. I'm using up years old scrap pieces as it is. (I never throw
ANYTHING R/C away!)
My life is controlled by my back problems and my back says that's it for today.......
Hopefully I can finish up the wing tomorrow. Then I just need to trim out the tail feathers with black. Do final assembly and fly! Weather is rainy and crappy for the next day or so then need some dry out time. IF the weather cooperates then I'm hoping for maiden this weekend AND a second flight on the Eaglet 250 . My fingers, toes and eyes are crossed......
I've given up trying to find a clear 4" canopy from the local cookie cutter Horizon Hobby controlled LHS's. I can order from Sig but shipping will be 2-3 times the price of the canopy! I'm still working on it.......
Joe
