OK, Here we go... down the rabbit hole.
The one thing, from the start, that set me off about this ARF was that something just did not look right in the nose. Back when I installed the cowl I quickly realized what it was and knew it had to be addressed. From the first two images today we can see the real deal compared to the model from Hangar 9. What's there that is wrong!? Well, the slope of the top of the nose. Note that the scale image is flying with cowl flaps closed and the model is full flaps open as part of the cowl mould. From there, move back. The model has this drastic hump that protrudes upward as well as having an abrupt slope off into the cowl. It makes the cowl look puny and there is only a 2mm gap between the top of the hatch and the cowl flap. Contrasting with the sides, there is a 6mm gap. This subtle difference completely changes the look and is just entirely wrong. Even 3-view drawings are not this bad. I have NO idea why H9 did this as the hatch is really what needs to be fixed.
Full disclosure... I failed to account for the cockpit floor when I installed the intercooler door servos. I removed the prior mounts but the CA was pretty stuch on there for one, breaking the former. Some simple ply was cut and the servo mountings were lower to give clearance for the hatch.
Time for carnage! I first cut the balsa skin at the former just in front of the cockpit. I chose this area because I did not want to run into fitting issues with the canopy when it is installed. I can blend and change in slope at this joint as well. From there I removed all the sheeting by breaking it away and then cut away the excess glue. I found it was some sort of aliphatic glue, quite soft, and was easily cut away. I created a template of cardstock from the profile of the firewall on the fuselage. Measured 6mm down and freehand drew the curve to blend it out. I cut the template and applied the curves to the hatch and the firewall. I used my razor saw to cut the two stringers at the sheeting joint and used a #11 blade to poke through glue joints. I carefully removed them as well as the two formers.
I sanded the hump out of the stringers and I was satisfied that I could re-use them. After fitting the stringer with the larger former I realized that I could re-use the larger former but not the smaller. The larger former I was able to cut the slots deeper and sand away the excess material for the new curve in the top. The smaller former had to be created anew. I used the inside curve from the existing former and cut. It was wrong but I learned what size I needed and how far I was off. The second one was great. I just used some scrap ply I had in my leftovers box. With the parts fitting well, I used medium CA to install the formers to the hatch and thin CA for the stringers. The fit is good, the shape is much better and the construction is sound. While there is some shadow in the picture, you can start to see how the hatch is now blending with the cowl, and not the open cowl flaps.
Aside from correcting the shape, the other reason I NEEDED to do this was to cut the cowl flaps to make them functional. I really liked this feature on another model I built (Corsair) and I'm excited to try it again.
