SuperFrodo
For the record, I did centre my servos. I'm 90% sure I did anyway...
So I just got my Libelle in the mail along with the servos and other bits Dream-Flight recommends, and I finished putting it together with barely enough daylight left to give it a few javelin throws to satiate my desire to fly a glider, and boy were those few throws a lot of fun. But an issue that I had prior to going out for a test flight is that I have tiny throws on the ailerons. I did dial in the end-point adjustment to get them moving a reasonable amount, but It's set to less than low rates and if I try to use flaperons I run out of throw to use for control (as in, the ailerons don't have any more travel after being lowered to the full flaperon setting).
This makes me wonder if when full flaperon is deployed, does only one aileron raise at a time for roll while the other stays down and doesn't move.
I'll take another look and watch some Youtube videos on setting up flaperons, but so far this has been a common theme. I end up with less throws than I should be getting.
