JMundy
I have a Lumenier Danaus 250 size quad that I built for my son. I just did the maiden and initially it flew good, so I decided to go into Autotune, but when I did it fell from the sky. So I picked it up, nothing broken and armed, but decided to keep it low to the ground to test it out. I hit the throttle again, and it flipped over and fell to the ground. At this point I was scratching my head... I did a thorough examination, still cant find anything wrong.
Next while holding the quad down on the floor, I armed and ran up the motor a little.... no problem. So I decided to push it, as I went to approx 5/8 throttle, each motor stopped at different points, then started and stopped... Problem found!! I am thinking that my amp draw is exceeding the ESC ratings, but not sure.
I have a Watt meter... here is what I found, at 1/2 throttle it reads 12A and 100W, above this point is where problems start happening. Suggestions???
Here are the spec on the Quad
Motor - Ready to fly quads x2204 2300KV (rating 490g of thrust with HQ 5x4 at 10.5A / 130W)
Props - HQ 5x4
ESCs - Lumenier 12 amp ESC with SimonK Firmware (Just noticed these are discontinued)
Props - HQ 5x4
