Hi, I might have a stupid question. I built my first flite test plane - explorer and I put my Frsky S6R reciever in there (i am using Taranis x7q). When I put any servo into the channel used for the elevator and I move the stick up and down (mod 2), the servo goes only like 45 degrees each way. When I put the same servo into the channel used for the rudder and i move the stick sideways the servo moves much further. I tried to play with servo endpoints (travel adjustment), but the servo wont move any further. My elevator does not go up and down enough. I checked and its not a mechanical problem on my plane as when i us the elevator with my rudder stick, the rudder moves much further. Also my stick goes up and down the whole way so I think its not an issue with the x7q hardware.
Any suggestions? Is it a firmware thing? Can you perhaps direct me to a similar thread? Thanks a lot.
